manual choke 1975 merc 850
merc75
I just got a 1975 merc 850 and noticed wire dangling from manual choke with screw and nut attached in eyelet of wire where does it connect? Is it to hole in choke linkage at top carb?
GA_Boater
Re: manual choke 1975 merc 850
Got your serial number?
Chris1956
Manual choke will connect to black plastic or nylon arm that controls the two carb choke shutters. There should be an plastic or nylon eye for it to bolt to.
merc850
850-choke.jpg The manual parts are in the square.
