I want to change to a five blade, high five with PVS perhaps, with the five blade should I go to say a 21 or 20 p and expect the same numbers as for top speed and WOT RPM?
Has anyone tried the PVS prop, and if so can you really get better hole shot with a taller pitch?
If I find a used prop with the same diameter,the pitch I want, but not sure about the hub fitting my leg, can a prop shop just press out the hub and put in the hub I need or is that a tall tail?There seems to be a few used ones out there that were on mercs that have 15 splines like mine, will they match up?
I removed my aftermarket fins off my leg that the previous owner put on, in an attempt to get over the 50 MPH mark,but have not had a chance to get the boat out yet, am I dreaming of that being a quick fix?
I have done a bunch of looking on this site, and know that stainless runs a bit quicker all around as it makes thinner blades, but is that going to be enough of a gain if I stick with a four blade
Any well tested advice would be helpful before I purchase as I can find an exchange dealer here,seems to be a foriegn word.
