oldironman57
- Jul 31, 2004
- 3
I have looked through alarm logs here a lot but don't find anything that fits my problem. The motor is on a pontoon boat and has had about 6 hours on a new impellor. We were in a large lake with a half hour drive time behind us mostly at WOT when the alarm went off...continous tone. I could not remember whether that was oil or heat. Restarted at idle with a good water stream so I thought possibly oil. Oil tank was 3/4 full with no visible bubbles in the lines. I mixed up a quart of oil into the gas tank with 9 gallons approx left in it. Better safe than sorry. Purged the fuel lines and let it idle for a while to empty out the carb. I was also holding on to the top and sides of the cylinders with no discomfort so I still thought cooling was fine. Odd thing was the alarm stayed on always when the key was on. No off at low rpm then on at WOT type sympton. We stopped and fished for a few hours and re-started the motor and instant alarm again. We started back to shore and the motor would seem to run fine until the last half mile in. We lost the any sort of high RPM. Motor would just die out above 1500 (approx) RPM. It would start and idle fine. Checked the temp on the cylinders again and seemed cool to touch, with no steam out of the tell tale. This is a 96 Mariner 60 (friends boat). I was wondering what is possessing this thing. The continous alarm leades me to a temp sensor. The loss of power scares me. Do these motors have any sort of limp mode? I had good smoke out the exhaust after dumping oil in the tank so I thought I covered that base. Figured I could always change plugs. Thanks for any thoughts. Randy S.
