Hey guys, got one for you. <br /><br />I got a 84 mariner that hadn't been run in a couple months. (2 Cylinder)<br /><br />Took it out and got it started, but it would go dead when I put it in gear. I ran it for a good while to make sure. I could throttle the engine up and it sound fine. <br /><br /> It didn't seem to be getting fuel pumped into it fast enough. The fuel filter on it now is in the glass case, and it appeared the gas was barely flowing in. <br /><br />I cleaned and regapped the plugs. (.024), took it back out and it started and went into gear on the first try. <br /><br />Only problem is that it topped out at about 5 miles per hour. <br /><br />Is this the carberator? <br /><br /><br />Thanks in advance
