mariner gears stuck
Loser
Hi- bought a tinny with a 5hp Mariner o/board & it started beautifully but when I got it home & took it out on the lake it starts but won't go into forward or reverse gear. The lever seems just totally jammed. Any suggestions guys? :confused:
WillyBWright
Re: mariner gears stuck
Check the gearlube. Check the linkages for free movement. Some motors won't allow shifting if the throttle is too high, check for maladjustment of that as well.
Loser
Thx Willy but should you be able to put it into gear when it's not going? 'Cause you can't do that either! (Oh I guess that's obvious) :confused:
WillyBWright
The motor or the prop need to be turning, or the engaging cogs could rest on top of each other instead of falling into place.
