Re: Mariner not getting rmp's in gear
Revving engine in neutral tells you nothing, other than the engine will run. Under a load is what counts. How do you get 30 mph at 2000 RPM? Most boats need over 3K RPM to plane. What RPM did you used to get?<br /><br />Carb or EFI?<br /><br />Have you checked the fuel system from the tank to the fuel pump for leaks and/or obstructions? Have you checked the fuel pump?
