Mariner or Johnson
utfyrfytr
I need to replace my old 75 merc 115hp that I have on a 1968 aluminum 17' Crestliner. I have been looking at two different motors that seem to be in decent shape. One is a 1981 115 Johnson and the other a 1989 Mariner. If everything is equal what would be your choice? Also as a side note, are the Mariners and Mercury's the same motor? Thanks for the input, I am really a novice at this boating thing.
flyingscott
The mariner would be my choice because it is newer. The johnson is a good motor that would be a good choice. Both motors would need to be checked out by a good mechanic. I also highly recommend test driving the mariner because it is a 2+2 motor. Merciry and mariner are the same motor.
kbh121956
Pull the plugs and do a compression check on each motor at WOT. They should not very much from each cylinder. Look up online what each outboard should have on compression also.
Sea Rider
How can you possibly perform a compression test at wot,..
Happy Boating
