Mariner Year Identification Help
sshaun
Hello,
I have an older looking 25 hp mariner. The tag on the hanger bracket is stamped with this code: S 007446 Can someone tell me what year it is an possibly how you found that out?
Thanks!
Dunaruna
Re: Mariner Year Identification Help
Manual start, short shaft. Made in japan in 1978.
Your serial number is incomplete, there should be 3 numbers before the 'S'. They should either 648 or 690.
outsick81
Thank you very much for the help! It looks like those first id numbers are just unreadable.
Shaun
Wingpilot
HI; I just acquired a Mariner 8 and I don't know what year it is. The serial # is 647L69635. Can anyone help with the year of manufacture? Thanks, Ed V.
dude11
That is good info--but as the poster inquired--how did you come up with the information?? Reason is;I also would like to find out the year model of mine.I'm told it's in the "numbers"???thax in advance,dude11
Dunaruna
Depends on the sequence of numbers/letters. In this case, even though the serial number was incomplete, there was only one year that contained the last 6 numbers in a 25hp mariner. This is not always the case.
There are plenty of serial number lists available on the net.
Dunaruna
You should really start your own thread with a question like this.
Your motor was made in the early 70's by yamaha. I do not have lists that early so cannot nail down an exact year.
