marinising a 2.5 td transit engine
siyman
Hi i am looking for info on marinising a 2.5 td transit engine to fit my fletcher 21ft . which motor is best and hopefully trouble free . i have a merc z leg so what type of conversion plate will i need . i have the use of a miller and lathe so tools will not be a problem . All advice will be welcome
cheers simon
Re: marinising a 2.5 td transit engine
Ayuh,... What's That,..?? never heard of a TD Transit motor,..??
i have a merc z leg
Mercruiser has Never built an outdrive called the Z drive,... Whatcha talkin' about...
Basically,... If a motor Hasn't already been used in a boat,....
It's Not really a Doable thing....
Mainly, Wet exhaust manifolds are the most serious Issue to deal with....
180shabah
I am guessing overseas, so anything could be possible from Merc.
If TD is turbo diesel, then like Bondo said your two big hurdles are the physical mounting and the exhaust.
mkast
turbo diesel
