Mark 30 water pump cartidge removal
phole440
Need to remove pump cartidge to pull drive shaft. Book says use tool number 91-22118A1 or equalviant. Thanks for the help.
Laddies
Banned
Re: Mark 30 water pump cartidge removal
If you don't find a dealer or shop with a puller and the number is 91-24162 you have the number the 40&44 cu. in. models you can in most cases tear the unit apart remove the pinion nut, place the drive shaft in a vice, heat the unit in the area of the cartridge, then useing a block of hard wood and hammer drive the unit off the cartridge, Use care to not damage the casting.--Bob
rodbolt
fhole440<br /> is that the tool to remove the pump cap? most of the old mark series used a threaded cap as the upper pump housing. the last mark series i restored I had to make my own spanners to remove the pump and propshaft bearing cover nut. was not fun and cost the customer a lot of coins but the tools have been NLA for 20 some odd years.f the pump cap is not removed no mount of beating will remove it. I have had to cut the cap off a few. saltwater will lock them as well as a weld.<br /> thats why I dont mess with them anymore.
phole440
Pump cover is removed. So i should heat the lower unit housing and hold the drive shaft in a vice and use a block of wood to hit the housing. Ill try it tonight.
phole440
Shaft is removed the heat and block of wood worked great thenks for the help. Paul
Laddies
Banned
I love those old motors Paul, God help us. Most of our fresh water motors from the 50 & 60s are in better shape than 5 year old saltys--Bob
