Re: Mark 30 water pump cartidge removal
If you don't find a dealer or shop with a puller and the number is 91-24162 you have the number the 40&44 cu. in. models you can in most cases tear the unit apart remove the pinion nut, place the drive shaft in a vice, heat the unit in the area of the cartridge, then useing a block of hard wood and hammer drive the unit off the cartridge, Use care to not damage the casting.--Bob
