Max RPM on johnson 70?
D
DJ
Guest
Re: Max RPM on johnson 70?
"Recommended" is 4500 to 5500. Time has told, that they live a lot longer if they are propped to turn at least 5500 with a light load.
That engine does NOT like to lug. It needs rpm's.
Shoot for 5500-light load.
w sajpel
i had a 1979 70hp johnson it ran about 4000 to 5000 rpm but i was told you can change the pitch on the prop you can get more out of it.
on the other hand if you turn too many rs you also can brun it up.
