Today when I was coming into the wharf after a mornings boating I was attempting to maneuver in to tie up when all of a sudden I was unable to select reverse. As I shifted the lever rearwards all I got was more throttle, while the drive stayed in forward gear. A few very anxious moments, especially since I had a ten knot wind from behind, and a tight space in which I was trying to maneuver, and some numpty pulling out in front of me in his forty-something foot launch.
Symptoms: the drive will shift from neutral to forward smoothly. However, if the engine is running the drive will not come out of forward until I switch the engine off. I can then restart the engine and it is in neutral. Once the engine is idling in neutral I can't select reverse gear; all that happens is the revs come up. The shift lever itself seems to still have unimpeded full travel.
The boat has only done around 25 hours since a new lower shift cable was installed , and up until today it has shifted flawlessly.
Where should I start?
Cheers
Cheers
