MC1 Gimble housing water tube smashed
ttownthomas
I'm monkeying with getting my motors lined up, im thinking that one of them is not in correctly and I realized that the shop that "installed" my motors also pinched a ground wire and smashed this Gimble housing water tube. I can see from the parts catalog that the tube runs THROUGH the transom assembly. How big of a job is it to get to this part? It looks like I would have to disconnect the bellows to get it out. I know I could take it back to them but weary about the quality of work over there.
kenny nunez
If you can get channelock pliers across and squeeze where the tube is kinked and then with a short 3/8’ drive extension in the tube while pulling you might be able to straighten it out enough. It does not have to be perfect.
ttownthomas
OH, I will definitely try that!
