omc cobra hole is the same as the later mc1 about 1975 up and the other after if you have earlier mc1 its not the same its almost the same maybe some old shops might have a template or a cut out does your mc1 have the trim things on the side of the gimbal or up the top above the helmet?
look in the stickies
first, click here https://forums.iboats.com/forum/eng...ion-for-diyers-an-work-safe-search-version-of
then under mercruiser, scroll down to installation drawings
however the cobra drive copied the mercruiser cut-out.
then the centre holes are in a slightly different place and the main hole is slightly too wide you might have to fill in the edges about a half inchTrim thingy is on the top....
