Measuring shaft
csisommout
1964 Evenrude speedtwin 28 hp 2cylinder. from where to where do I measure the shaft? to find out 15" or 20"inlength. Thank you
Cal s.:confused:
Chris1956
Re: Measuring shaft
Measure from where the motor would sit on the top of the transom to the antiventilation plate. I will likely be about 15" in that year motor.
chriscraft254
Re: Measuring shaft
F_R
Re: Measuring shaft
Those motors were engineered to run on wood boats. The cavitation plate runs about an inch BELOW the boat bottom. In other words, expect to measure about 16 or 21 inches from the top of the transom to the plate. More or less, but certainly not 5 inches more or less, the difference between long and short shaft.
