[insert Beaver Cleaver voice] "OK, Wally. I'll try it your way." Soon!
Ran outa light after work.
I reconnected everything and fired it up. Since the DVA was right there, I checked the trigger wire voltages. All around 2.5V-3.5V DC.
BTW, these are used CDI's not the originals. (I replaced one and problem endured, so I bought a second one from eBay)
I only had a little bit of light left, so I started by doing the test where you disconnect the white wire (kill switch wire) on one, then on the other CDI. If I understand the troubleshooting guide, if you disconnect one, and the spark comes back, the opposite pack is bad.
With both CDI's connected:
#1, 2, and 3 all fired good.
#4 was very dim.
With the white wire from the aft CDI (fires plugs 3 and 4) disconnected
#1 No spark
#2 Fires
#3 Fires
#4 Fires bright (!)
With the white wire from the forward CDI (fires plugs 1 and 2) disconnected.
#1 No spark
#2 Fires
#3 Fires
#4 Fires (brightness varies, goes out all together when you turn the ignition off, but engine keeps running).
Not sure that it matters, but with either white wire disconnected, the engine kept running even when I turned the ignition off, which is what I expected. But the RPM dropped. With the aft box disconnected, grounding the stator wire labeled #3 killed the engine. With the forward box disconnected, grounding the stator wire labeled #1 killed the engine. Having re-read the instructions I see that the right way to kill it was to ground the disconnected white wire. Duh.
I don't know what any of that means!
I'll do the "swap the CDI's" test on Saturday, Lord willing. Gets dark early out there!
