Can anyone give me an idea where to lok for my problem. This is the problem ,the motor runs great from idle all the way to wot and great for a long while then it will start to slow down ,almost like it is runing out of fuel . This is what I had tried, I replaced the fuel seperator filter drained the tank [ which was clean ]checked the fuel lines. I should add that I had a problem with water in the tank early this year, which I cleaned the tank out along with the carb's. The motor runs real good untill this happens, and when it does the primer bulb does not have fuel in it so I am thinking that maybe the fuel pump ? I did pull the fuel line off of the output side of the pump and cranked the motor and it did squirt fuel , so I not sue { just do not want to throw parts at it I am on a tight budget ] Any help would be great,Thanks
Rick
Rick
