MERC 200 EFI 2001
FASTFISHER
I WAS OUT YESTERDAY AND THE BOAT WAS RUNNING FIND AFTERLAST SPOT WENT TO TAKE OFF AND BOAT WOULD NOT GET ABOVE 2000 RPMS. IT WAS VERY COLD OUT AND IN NEUTRAL IT WOULD REV AS HIGH AS I WANTED TO GO . I NEED HELP SOMEONE SAID POWER PACKS WHAT DO YALL THINK.
rodbolt
Re: MERC 200 EFI 2001
hello<br /> sounds like some methodical planned trouble shooting is in order. or just start tossing parts at it. good luck and keep posting
FASTFISHER
I HAVE TO SAY . IWAS HOPING YOU WOULDN'T SAY THAT.<br />SOMEONE HAS HAD TO HAVE SEEN A SIMILAR PROBLEM.MAYBE GET IN THE BALL PARK SO I NO WHAT PARTS TO THROW AT IT. THANKS<br /> J-BIRD
rodbolt
first thing is buy a manual. second is buy a peak reading voltmeter or a Fluke or other DVM that has a peak volt adaptor. did you check your fuel system? when was the last vapor seperator filter replacement? you know the cheap one on the high pressure pump:).<br /> if you toss parts then switch boxes are about 190 or so apiece. the stator is about 360 the trigger is about 180 the ecu is about 900 or so. manuals are much cheaper. the factory manual gives a desription on how the ign and fuel system work.<br /> good luck and keep posting
rodbolt
hello<br /> I forgot you will need a compression guage and a spark tester. make sure the engine compression is good first then test spark. could be a bad low pressure pump or a coil. thats why I said a methodical test of the ign and fuel systems but start with a compression and spark test. some of the guys here have made some good ones out of scrap.
FASTFISHER
I GUESS I WILL START WITH SPARK AND FUEL FILTER AND GO FROM THERE I WILL KEEP YALL IN TOUCH.<br /> THANKS <br /> JAY
robalofish
You may also want to check the caps lock on your computer people might accuse you of "YELLING" with all caps. <br /><br />By far the best thing to start with is the Mercury Factory manual. They have all the steps for troubleshooting.<br /><br />Good luck<br /><br />RFish >()> :p :p
