Merc 260M/carb Identification, part needed
Osprey55
My mechanic lost my choke vacuum break rod for my Rocherster quadrajet. The I.D. tag is long gone from the carb.
My engine serial number is 6817160 and the model is 02608344.
It runs well and he indicated that the rod isn't really necessary !?.
Does anyone know how I can determine the model of the carb and locate a
replacement rod?
Thanks in advance for any help. Jim
Bt Doctur
Re: Merc 260M/carb Identification, part needed
post a pic of the carb, have a couple of parts carbs laying around that might have what you need.
Ayuh,... It's a Rottenchester.....
Over the years, Only the Rottenchester, then the Weber/ Merc. carbs have been used on the 260s...
Osprey55
here's a couple of photos ( if I am doing this right.. please bear with me ).carb1.jpg
Bt Doctur
got a spare you can have ,pm your addrress to me
FreeBeeTony
Isn't this forum great???
Where else could you get help like that.........from someone you have never even met!!!!!
Osprey55
What a resource! Bt Doctur, I really appreciate the help. I sent a PM.
You are setting a great example in sharing that we will all copy.
my boat is a 1983 Sunrunner 245, now in Conroe,Texas. It survived
Hurricane Ike and is on the way to being herself again.
Thank you for helping get my old boat back in the water.
jtybt
Tell ya the truth, unless you boat in extremely cold weather, the choke isn't even needed. I even took off the choke plate and rod on my Q-jet about 10 years ago. I'm in the SF Bay area and it is usually cold and foggy here. No problems.
Bt Doctur
Choke maybe, this is for the vac sec that hook to the vac pull off
In the mail ,pm`d you.
jtybt
...to keep the secondaries from opening too soon...Gotcha. Just didn't look hard enuff.
