Merc 3.0 running rich?
beason
I have the 4 cyl merc 3.0 in my 17ft boat and burned an entire 22 gal tank in about 9 hours of lake time. (not all running, but probably 80%). I can smell gas fumes at low speed, it idles rough, and if i dont let it idle for 5 seconds or more after throttling back to neutral before shutting it off, it will diesel, and knock.
Does this sound like a rich condition? If so, does anyone know how, or have documentation on how to adjust the carb? I downloaded the service manual for the boat, but I would like to have some personal experiences before diving in.
Re: Merc 3.0 running rich?
Ayuh,... It sounds rich...
Rebuild the carb, 'n reset the internal settings...
Probably the float setting, but who knows til ya tear it apart...
beason
any info on how to go about doing this? I was told it was rebuilt last year, so maybe its just an adjustment needed.
Thanks
LilRedNeckGirl
a 4cyl engine at full load burns how many gallons per hour? you say 9 hours, 80% run time, so apx 7.5 hours running? Im guessing water sports so high rpm, heavy load. IF, you burn 3 gal an hour, thats your tank full in 7 hours. You may have other issues related to the after run and gasoline smell, but im thinking your consumption ratios are near where they should be. Your options for 9 hour days on the water may best be solved with a bigger tank.... nPersonaly, I wont leave the dock without topping off my 100 gallon tank.....
AE; I run twin 3.0's. (140 horse mercruisers} 30 gallons gets me about 5 hours of run time with both running at 3000 rpm. ( apx 80 ~100 miles over the weekend) twins run at a lighter load as two props are pushing the boat. factor in no major chop or waves, just an empty boat on plane in calm river conditions. be glad your running a 3.0, as bigger engines are measured often , in gallons per mile.......
Another check is your prop. Right pitch? good condition?
Then examine your habits. are you cruising at a reasonable speed on plane or are you running full slam wide open? Lots of factors influence your consumption rate. And just a fyi, running wide open heats up an engine, which could lead to after run and gasoline smells when you stop.
beason
it was over 2 days. the first day was 6 people in the boat and dragging the tube all over the lake and burned about 3/8 tank in 5 hours. the next day was 4 people and some tubing and kneeboard attempts for 4 hours that ran me almost dry. I guess i just have to fill up before every outing.
I have the 19pitch power prop on the boat, and i almost never run wide open, mosty just up on plane and cruse. the lake was very choppy both days so maybe that was an issue.
I am still concerned about the dieseling at shutdown, and the rough idle.
thanks for the info!
