merc 5.7 close cooling system, was running great took it out to fishing ground today. runs great for about 30 min then the gauge start climbing from 180 to 190 then it about to hit 200 i shut it down. we sit on the anchor for about an hour to let it cool down, re start and the guage start climbing again with the antifreeze over Flo tank just spilling boiling over. at this time we call the towboat us , when we got back to the dock we install a new raw water pump start the engine, the risers felt cold and nice, the manifold felt hot, foget to mention we took the thermostat out on the water , so with this new raw water pump install we are running without a thermostat . ok so at idle the temp start rising again i put in nutral and hold the rpm at 2500 the guage fel like a stone to 120 as i stated the thermostat is not in right now, i will install a new one tomorrow .
ok guys raw water pump is new, could it be my circulating pump shot?? or maybe a head gasket?? or it need that thermostat ??
full close cooling system only the risers get raw water.
also it has a belt driven raw water pump. thanks for any info guys.
