hello. I have a 2005 merc. 50 hp 2 stroke that is stalling out at low rpm. i have to pump the primmer bulb to re start. ive replaced the primmer bulb which did not fix the problem. Anyone have any other ideas? ser # is 50ELPTO. Thanks
you have a fuel problem. Either you have a leak in a fuel line before the fuel pump or your fuel pump is not working, has a broken diaphragm. When you pump it up without starting the engine, hold pressure on the bulb after it gets to max firm. Does it leak down? That is either a float leaking, which is not the problem you are reporting, or a leaky fuel line. If the bulb stays firm, I'd recommend you get a kit and replace the fuel pump diaphragm.
