Merc 500 slowing down
tzambo
I have a 1967 Merc 500 runs great just got the boat to trim up properly. I do have one problem once on plane after a litle while the motor just starts slowing down. I noticed that if I bring it back down to idle and hit the throttle again it runs just fine for a bit then does it again. Could this be fuel starvation?
coolguy147
Re: Merc 500 slowing down
overheating?
if not done so already lately i would replace the impeller though
tzambo
Impellar is new, and there is plenty of water out the tell-tale. It only happens when it's WOT. I ran the other day for about 3 miles at about 1/2 to 3/4s throttle for about 3 miles and no problem. So I think i can rule out overheating.
Aqualift
Check or replace the fuel pump diaphragm.
coolguy147
pump primer bulb at wide open if problem stop then check fuel pump and replace neseccary parts
