andrewkafp
- Mar 15, 2003
- 1,668
My first outboard/boat.<br />Tinkering around looking at my motor, there is a pull cord located in the end of the case in a plastic bag. To use it if the electric starter failed, I would assume you would need to remove the top cover as well as the side wrapper type cover. Question... How do you get it OFF ????<br />It looks securely bolted, and is used to tilt the motor. Is there a release catch located somewhere, or do you just get the tool kit out in the middle of the ocean and start unbolting ?
