Aquired this engine a week ago (serial # 2084266.). Believe it's a 1996 merc model 60 6hp. Engine would not start, had fuel and spark, but would only start with with starting fluid and run very rough. after inspection of the points in the stator, only 1 side opens up when cam is turned, other side remains closed on every rotation. So I assume this would cause only 1 cylinder to fire. Every where I look I can't seem to find specs.
Also after bringing plugs to local marine shop they told me the NGK plugs I had were automotive and not marine, can anybody recommend proper plugs. Also had no specs for points and said "eye it up". To side that is opening. I'd like something a little more legit then eyeing it up
-Ryan
-Ryan
