Merc 650 lower unit repair (newbie)
87racer
Re: Merc 650 lower unit repair (newbie)
i was just thinking of that groove on the top of driveshaft.but couldnt think of why it would be there. you just confirmed that idea.. thank you so very much O-WISE-ONE !!!!!
87racer
ok, got it together but the shift seems to be off. i tried to index it upon removal but something must have moved. i assume i have to drop it a bit to realign the shaft. any ideas??? how to etc???? also i marked the brass type lift piece that encircles the shift shaft. is that a possible cause??? thank you in advance
Wingedwheel
One thing that was not mentioned and is important is which way you put the shift cam back on. It will go on either way bit there is an upper and lower side. Some are marked and some are not. If you put it on correctly and things are still not right you might just have to turn it further around until you get it in the right position. It may have just gone past and be pushing against the cam follower from the back-side.
87racer
i think i am just off a bit cause i can hit all 3 gears. so i have to drop it but i was lookin for some tips to re align it. i did put the cam on right side up. the new one was even marked !!
my issue is i have to go way into rev to get the reverse shift
Wingedwheel
I had a similer problem and it baffled me for awhile until I did some sectioned trouble-shooting. The lower unit shifted fine by hand, the cable on the shifter was adjusted fine, but wouldn't go completely in reverse so I eliminated those two which put the problem in-between. I figured the only thing left was the coupler and sure enough, it had worn splines. I replaced it and everything works like new...
