jmccartney@indy.rr.com
- Jun 13, 2003
- 7
I have a 1982? (s/n 5816301) 7.5 hp Merc that went swimming last summer. It was running went it went in and spent about 5 minutes underwater. We pulled it out and got it running right away. It starts and Idles fine but at about 3/4 throttle it starts to sputter and will not come up to speed. Plugs have been changed, a different carb was tried and still the same problem. It starts fine and runs good until about 3/4 throttle. When I leave it at 1/2 throttle and manually open the carb butterfly(?) it seams to want to run. <br /><br />The Carb has been rebuilt, sprayed 1 can of decarb(changed plugs again)
, and checked the gas line(the bulb stays hard). <br /><br />What should the compression be? It is 90 on both cylinders.<br /><br />Any suggestions on fixing this would be of great help.
