Merc Alpha4 no longer available. What to replace it with?
QBhoy
Well I should start another thread for me. Let's see what Chris comes back with.
Agree. Fair comment. Happy to share what I’ve tried on a few similar boats and my own inboard. Tried so many props on that I was verging on silly. Haha.
Scott06
Scott. What pitch was that rev 4 that managed quicker than the enertia. Would love to see a tempest plus of same pitch on your boat and see how it goes. I’ve been amazed with the Tempest so far.
21” rev 4. My boat has a steeper drive ratio 1.81 than is typical. Boat originally was a 4.3, previous owner cracked the block, i bought it knowing this. when i repowered i put in a 5.0 but didnt want to regear or swap the drive since it only had 37 hrs on clock... bottom line works perfectly just pitched up 2”.
i think the reason the rev 4 did better in my application is i can fully trim out and get more of the hull out of the water. running straight i couldnt do that with either the vensura or enertia. I think my boat is beamy, arse heavy, and has a steeper deadrise...throws a big wake if you are skiing, ok with the wakeboard.
ill send you my address as im sure you have a spare tempest or two you can loan...
Scott06
Scott, just so we can compare I think you left off the pitch of your Rev 4. Also, why such steep pitch on the Spitfire? Doesn't seem fair to that product.
Rev 4 pitch is 21”. the spitfire 23” is right at the rev limiter so i would have been over with a smaller pitch. compared to the sales pitch in the merc literature i gotta say the spitfire wasn't impressive.
I have a 1.81 drive as my boat was originally a 4.3 powered boat that i repowered with a 5.0. onky had 37 hrs on the clock so went up 2 “ in pitch instead of regearing the drive
achris
More fish than mountain goat
Hi chris.
I think this is a tough one. Having only the vengeance to compare, I think isn’t doing the 3 blade props any justice. They are terrible props, to be honest. I’d urge you to try a tempest plus of the same pitch. You’ll find so much more grunt everywhere in the range and I’ll bet my life on it...better cruising attitude and 100% more top end. Better still, you’ll be taken just off that limiter by a little too. As for the Rev 4...they take a hellish lot of power to turn them well. Hit or a miss on boats like these. Honestly...try the tempest plus. Bigger diameter than usual 3 blades like laser and vengeance and come alive mid range and blistering top end.
In the past I did try a Mirage, which is also a bigger diameter. The larger diameter generates bow lift, which my hull absolutely hates. Makes it slam. I really want to get back to a 4 blade because with the higher rake they don't pick up the weed so much. We have a reasonable amount of floating dead seagrass at this time of the year (and before any storm) and the 3 blade props pick it up like cheap women. (family friendly ;))
I'll be talking to a prop specialist shop tomorrow, and my local Merc dealer has a few 4 blade SS props available. We'll see how we go.
Stinnett21
Chris just curious, did your Flo torq hub give way any or was it all absorbed by the ally prop?
achris
I was only doing about 6 knots and the impact was soft enough hit that only the ali blades took it. The hub was fine. Another reason I want a SS prop. They're stong enough to handle a soft hit without breaking (this hit actually tore about 10mm clean off one blade), and when the hit is harder, their extra strength ensures the hub is the part stressed, not the prop. And a bent SS blade is easily hammered out. Once you bend ali, trying to hammer it out usually results in a cracked blade. DON'T LIKE ALI PROPS!
achris
I have an update, with bitter/sweet results.
I contacted my local friendly Merc dealer and talked to her about props. Cost of a new Ali prop is around 400 Australian micro-dollars. Bit more than I was expecting, but what can you do. I asked about second hand SS and she said they had a few, and I was welcome to come and have a look. Did that yesterday on the way back from a morning out divering.
She had a 19" Revolution4 there, so asked if I could take it on test. If I liked it, $550. At that price, I'd take it...
Took the boat out this morning with that prop loaded on. WOW! Love this prop. Handles beautifully, didn't matter what I did, turning sharp at speed, crossing boat wakes at the 'wrong' angle, trying to wave jump, it would NOT let go. It was only when I started to trim WAY up that I could hear it pulling air, and that was very close to the trim limit, at 28 knots!
I love how responsive it is to trim, and when trimmed right in it doesn't vibrate like a 3 blade. It's so smooth when running, and even at 2400rpm (which is just on the bottom of the power band for this engine) when I pulled a very fast full lock-to-lock turn the engine only dropped 200rpm.
Someone here said that the Revolution4s need 'lots of torque' to turn them. That didn't feel like the case here. I was watching the fuel flow meter and flow was a little less (for any given boat speed) than that of the 17" Vengeance, but that could also be because the boat was light loaded. So I'm going to call that one as the same. In all other comparisons, the Rev4 eats a 3 blade.
Now the bitter. Max revs only 4450 (and doing 39 knots!). Right on the bottom of the range, and it was only me and 150L of fuel. When I load up (dive gear, dive buddy and boatie), we're going to fall off the edge. I think a 17" will give me 4950. Perfect :)
Very sadly I will be returning this prop, but if a 17" becomes available, I will be the first in line.
TL;DR Revolution4 19" pitch. Max revs 4450, 39 knots. No bow lift (which is good for my hull), and felt strong and grippy right through the rev range.
Chris......
QBhoy
TL;DR Revoltion4 19" pitch. Max revs 4450, 39 knots. No bow lift (which is good for my hull), and felt strong and grippy right through the rev range.
Chris......
Urge you to try a tempest then chris. It’s just a 3 blade version of the Rev 4. Worth a shot, if you can get a hold of one to try.
achris
Why are you insisting on me using a 3 blade when a) I've already got one, and b) I've stated many times I want a 4 blade?
I think you may have missed the point of why I want a 4 blade, so I'll say it again. In my area floating dead seagrass is very prevalent. 3 blade props pick it up like morons pick up toilet paper in a pandemic. With the higher rake and smaller individual blade areas, 4 blade props don't tend to do that...
Chris....
QBhoy
Chris....
Jesus Chris. I’m not insisting on anything fella. Was just trying to help and share what I’ve picked up on props, from messing with them a fair bit. I’m amazed to be honest, that there is such a difference in a props ability to pick up weeds between a 3 blade and a 4 blade...but it’s something I’ve no experience with, to be fair. You go your own way...but I was just suggesting that if you like the results of a rev4...you’ll love a Tempest plus.
achris
.... I’d urge you to try a tempest plus of the same pitch. ....
Urge you to try a tempest then chris. It’s just a 3 blade version of the Rev 4. ....
.... I’m not insisting on anything fella. ... if you like the results of a rev4...you’ll love a Tempest plus.
Looks pretty 'insistent' from where I sit.... Gotta give you credit for persistence though.
Oh, you have a PM. ;)
achris
... Was just trying to help and share what I’ve picked up on props, from messing with them a fair bit...
I used to be a Merc dealer and I have probably played with more props than you. It was one of the services we offered our customers. Full trial of any props they wanted. When I first got the dealership I had the Merc head office in Melbourne send me a whole bunch of props. Different styles, different sizes. I took a few differently powered boats to the river one weekend and run all the different props on each of the boats (obviously the right prop on the right engine) and got a real feel for how each different prop performed. That way, when a customer asked me about the various propellers, I could give an informed opinion on each. Advantages and disadvantages, and performance criteria, and not just what anyone could read out of a sales brouchure.
.... I’m amazed to be honest, that there is such a difference in a props ability to pick up weeds between a 3 blade and a 4 blade...but it’s something I’ve no experience with, to be fair.
Right there!
QBhoy
Right there!
There is just no pleasing some folk. Maybe there is no point in you even asking such a question in the first place chris. Sounds like you know it all anyway. Was this question only posted...so you could answer it yourself ? What a man 😂
At least others now know fine well...not to even attempt to help or reply to any of your posts, going forward. For fear of a barrage of abuse ! Lesson learned for the forum, I’d think 👌
achris
Sincere apologies for any offence. That was not my intention. I just wanted information about the latest 4 blade props available, as the newer ones weren't around when I was a dealer.
QBhoy
J
no worries. The Rev 4 is a great prop to be fair. Often need to go down in pitch, as you’ve said though. That seems to be a common thing. It’s worth seeing if they come in one inch increments chris. I know some of the new expensive merc props certainly do. So an 18 might be good too ? If there is such a thing.
achris
To give this thread some completion, I'll update it now.
After having phoned all the local boat shops, and visiting a few specialist prop shops, nobody had a Rev4, 17"... So I placed a 'Wanted' ad in our local Gumtree (website, not actual tree). A week ago a guy calls me and says he has one. Great! Then he gets home and checks, it's an 'Offshore', not a Revolution4, but it is 17" pitch. Anyway, I bought it, having had Offshore props on my old drive...
Took it for its first spin today (pun intended).... With 2 up, 145L of petrol in the tank and 2 sets of scuba gear, hit the rev limiter (4950) at 38knots. Felt really really smooth, and the hull just did what it wanted (no bow lift!). The boat felt great, the best it's felt for a long time. Cruising speed is up by about 8 knots! The trim control was solid, it came out of the water quickly and with far less stern 'ploughing'... I'm very happy with it...
As an aside (and I think @QBhoy will find this funny), the guy was trying really hard to get me to try an Enertia (3 blade) prop, promising I'd really love it... 🤦‍♂️
Chris..........
Scott06
Chris..........
I ran an offshore ( I think they also called it vensura at one point). Worked very well, especially on holeshot for watersports. I had a fair amount of slip with it on the top end and wouldn't stay hooked up with more than 1/4 trim out.
The results you outline are exactly the reasons I reccomend 4 blades, it improves the boat perfomance in almost every category except top speed, which you rarley get you use.
I'd be interested to hear your results if you can get your hands on a Rev 4, took me about year to find a decent price used one on ebay
achris
I had a 19" Rev4 on trial, but the engine revs where right at the bottom of the range. Not ideal. Sadly I had to take it back. It was everything the Offshore is, and more. Will keep my eyes open for a 17" Rev4. Then the Offshore will be on the market.
