merc steering rod threads stripped.
andrewcoon
Like the title says they are stripped from pounding the steering rod in. Tried a die and that didn't work I've been filing it down but it won't go on straight): this is sea Star steering. Thanks guys
roscoe
I'm a bit confused by your "pounding the steering rod in" comment.
What is stripped, the end of the drag link which goes through the rod on the steering cable?
Steering cable should slide into tilt tube, and drag link should drop into end of steering cable.
Do you have the correct drag link for your motor?
andrewcoon
No Title
The Threads On This Are stripped
Ayuh,...... If ya can't fix it, contact Sea Star for a replacement,.... it ain't a Merc part,.....
