mercarb on 3.0l not spraying any gas
snake91876
i have a 87 3.0l with mercarb two barrel, the bowl fills up with gas but the accelerator pump wont spray anything. Mechanic says the accelerator pump is good looking , good rubber , and springs strong , could the carb be stopped up i cleaned good. when you spray cleaner in accelerator pump well comes out of little hole in bowl is this right.
