Mercarb
Brad S
Can someone tell me what the difference is between a mercarb 815396 and a 815397?
NHGuy
Re: Mercarb
And to add. Get the exact one for your application!
Brad S
Re: Mercarb
Should I re-build this carb or should I replace this carb with Rochester replacement?
90stingray
Re: Mercarb
I would not go with the Rochester... i bought one once. Mistake. Fits like crap on my rig. Had to rebend fuel lines, grind thermostat housing to clear, and some other issues. Ended up pulling it off and selling. Just rebuild what you have... $50 rebuild kit and some time and you are good to go! Hope this helps...
Brad S
Re: Mercarb
Now have what appears to be a carburation problem When motor is cold and warming up (1-2 min) it idles fine As it warms it stalls out and dies I can restart it but I have to pump the throttle and set it approx. 1/2 throttle for it start but runs extremely rough and dies again If I keep trying torestart it it will start to pop back through the carburetor
achris
More fish than mountain goat
Re: Mercarb
Sounds more like a fuel pump problem or a loss of fuel in the line to the pump.
Don S
Re: Mercarb
Have you replaced the fuel filter in the fuel pump? Or checked the filter in the inlet of the carb?
Brad S
Re: Mercarb
Took fuel line loose as soon as it died and was getting plenty of gas Engine will keep running if spraying starter fluid in carburetor Have not anything with the feul pump yet
Re: Mercarb
Ayuh,... Then My guess is the filter in the carb's inlet fittin' is 'bout plugged up....
Best bet is to replace Both of the filters Don's talkin' 'bout, 'n plumb in a canister type filter, just before the fuel pump....
Brad S
Re: Mercarb
Think I will rebuild the carburetor THe carb is as old as the boat I would suspect that it is probably just time to do it Will post back
achris
Re: Mercarb
And lose the starter fluid, unless you want to be rebuilding an engine very soon....
Brad S
Re: Mercarb
Used it only to see if it would stay running. Not something I usually use.
