Mercruiaer 350 Timing jumping around. Low WOT
muc
"Retired" Association of Marine Technicians...
IEven just moving the connection wires slightly at idle will cause the engine to die
Suggest you get a copy of MerCruiser service manual #17
It will have wiring diagrams and the instructions on how to resolve your problem.
If you have any questions after reading it, I’m sure we can help.
fishngolf
New Cap and Rotor didn't change anything. I also ran a direct cable from negative battery to studs on the block no change. Pulled plugs and #8 killed the engine right away. This is also the cylinder where I had low compression originally.
