mercruiser 110 wont wind up
1966starcraft18ft
Hey all. so, i got my ignition issue figured out. put on a ballast resistor and correct coil and it fired right up and idled but it won't free rev beyond 3500 rpm. wide open it plateau's at around 3500. if you back off to bout 1/2 throttle, it will rev up to bout 5,000. this is in the driveway with muffs on. i know it prolly ain't good for it. thinking it's a fuel issue. I will be picking up a new fuel/ water seperator after work and putting it on. i have not done a fuel flow test yet.will also be checking the timing.
alldodge
Hey all. so, i got my ignition issue figured out. put on a ballast resistor and correct coil and it fired right up and idled but it won't free rev beyond 3500 rpm. wide open it plateau's at around 3500. if you back off to bout 1/2 throttle, it will rev up to bout 5,000. this is in the driveway with muffs on. i know it probably ain't good for it. thinking it's a fuel issue. I will be picking up a new fuel/ water seperator after work and putting it on. i have not done a fuel flow test yet.will also be checking the timing.
Your correct that isn't good
You sure your tack is working correctly?
Ayuh,...... What were the results of the compression test,..??
fishrdan
1966.... I would check the distributor's weight's and springs to make sure they are free and moving as they should, lots of rust and funk can happen in 50 years. Open the distributor, remove the points plate and see what lies beneath....
