mercruiser 120 no spark
weightset
Re: mercruiser 120 no spark
well when i first set the voltmeter on the coil today i started at 11.2 until i started to crank then i only ended up with the 4.2v what do you think would have caused that, and if you were in my shoes where would you start at to get spark
Don S
Weak battery, loose, corroded, failing battery cable connection. You name it. You can't get 2 tests to match or come close to the same, so it leaves your testing methods in question.
weightset
Well i got the boat running was a bad coil as i first thought. But now i cant keep it running unless have a small amount of throttle on
NetDoc
With that low of voltage, it sounds like you have a ballast resistor and one that is failing at that. If not a ballast resistor, then the Oil Pressure cut off switch could be the issue.
I agree with Don though: change points and condensor, set the gap (dwell) and go from there.
dubs283
huh??
never heard of an oil pressure cut off switch on any mercruiser product
there is an oil pressure switch for the alarm system on some models
and an oil pressure switch on carb engines with electric fuel pumps
but neither of those two systems has anything to do with the ignition system
