This motor is on a 1980 Century boat. The motor is the original motor on the boat. I've been having trouble with it overheating since I towed a stranded boat back to their dock. The tow was about a 1/3 mile through shallow, sandy water. My plan is to replace the sea water pump and the impeller on the lower unit.
I've never done this before, so I've studied up online. From what I've found, the replacement kit I'm thinking will fit the bill is [h=1]Mercruiser New OEM Sea Water Pump Repair Kit 46-807151A14[/h]
Also, I'm hoping this video is the process I need to follow, and all this work appears to be on the lower unit, by removing the lower unit, and nothing required in the engine itself.
https://www.youtube.com/watch?v=UkOWt7TlKAg
The serial number of my Engine is 5581049 and the Stern Drive is 5521930 if that helps you know my exact year\model.
If you have any tips or confirmation of the process, please let me know.
Thanks,
Jon
Thanks,
Jon
