mercruiser 170 bogs down > 3700 rpm
Mahoney
Re: mercruiser 170 bogs down > 3700 rpm
As recommended by Bondo, you must go with the marine fuel pump to match your application. I found my older pump at a place called boating solutions in the tri-cities(washington) it was significantly less than ahywhere else I could find it(even with my washington tax)<br /><br />I talked to sales on the phone, and they seemed very knowladgable and helpful(verifiing many of the symtoms I described and recommendations by the forum members)<br /> https://www.boatingsolutions.com/
mm82831
thanks mahoney for the info. you have the right pump. my research shows a rebuild kit might be available for this pump. anyone have input if this is a good alternative? are any special tools required to do the rebuild. thanks.
