Hi! Working on an old project boat with a mercruiser 2.5 engine (first generation block with a cilinder head, studs and hydraulic valves from a second generation block). I've been bashing my head recently on a tick that's being produced by the engine and I just can't seem to resolve it.
The tick seems to be coming from the left side of the engine, close to the camshaft and lifters. I've already adjusted the valves (multiple times), cleaned all hydraulic lifters and checked if the tick is also there without the fuel pump installed. It's linked to the RPM, as you can hear in the video below and definitely sounds to becoming from the push rods area.
Nothing seems to be working and I'm pretty much at the point of lifting the engine and opening up the oil pan to see if there's anything suspicious with the cam and such
Before doing so, is there anyone here that recognizes this sound and can point me to something? Or convince me that this is supposed to be there (which I can't imagine most as I've not heard it before) Thanks!
The video with the sound of the tick at different rpms:
