Scott06
- Apr 20, 2014
- 7,095
you could probably get an idea of the back lash in the timing gears by turning the crank back and forth and seeing the delay in either rocker movement or the rotor in dizzy turning.I've got no tools to pull the crank pulley so can't look at the gears atm, but feels like that would be my next step(?).
Also did you run it with the block circulating pump belt off. Possible if the bearing in it is bad it could make noise
