i_build
- Apr 24, 2005
- 144
There was a home made 90* brass inlet into the thermostat housing that the prior owner rigged up. It was almost completely clogged with the pieces of impeller. I removed the 90* fitting since the inner diameter was smaller than the feed line and simply used a longer length of hose however if the same thing happens now I am concerned the piece could make it to the block. Was wondering if there was a screen or some type of 'filter' that I could put inline. I see that the power steering cooler is what tends to capture impeller pieces for engines that have them... but I don't.
