Mercruiser 3.0 Alfa One not starting
Trichard310
Hello everyone, I have a 1996 Bluewater boat with 3.0 mericuiser. Started the other day just fine. Went to start it today and it just cranks. I sounds like it wants to start but won't. I've got fuel and spark, not sure where to look next??? I just bought the boat and it's my first. Any help would be appreciated.
Trichard310
have you set the choke and pumped the throttle when attempting to start?
If u were talking in car terms, I would know what ur saying. There is no choke to set, unless I play with it on the carb with my fingers. Throttle is neutral to start, can't pump the trottle while cranking. I have pumped the throttle a few time before I crank. This is what it looks like. Like I said, I'm brand new to anything boat.
Paintman1960
button in center will allow you to be in Neutral, will allow to to set choke and pump throttle,
Boat looks clean !!
Trichard310
Boat looks clean !!
Well hotdog...that worked. I really don't know anything about boats at this point. Guess I better get researching. Boat is clean, thank u.
dubs283
If u were talking in car terms, I would know what ur saying. There is no choke to set....can't pump the trottle while cranking.
i don't discuss cars on this forum
all mercruiser carbureted engines come with an oem choke that can be set when attempting to start. the remote handle ought to have a throttle only setting, again an oem feature
