Dbowperson
- Oct 5, 2009
- 4
I just recently had a problem come up with my charging system. The last time out, the alternator quit charging the battery. I was on the other side of the lake when it died on me, of course, but I was able to get my hands on a jump box and make it back home. I did some quick checks with a volt meter, and I am only getting 11.8-12.0 volts at the battery with the engine running. I am also getting the same voltage at the main post (large orange wire) on the back of the alternator (Mando AR-150BA 12V/55amp). Is there any way to tell if the alternator itself is bad, or if it is the voltage regulator on the back of the alternator? It looks like $30 vs $100 depending on the problem. Is there any chance the problem could be with the battery or something else in the system?
Thanks for your help.
