aidanmurphy
- Apr 2, 2022
- 113
Just picked up a new to me 1991 Stingray with a Mercruiser 3.0. Boat ran great the first 5 times I took it out. Last time I was out boat was hard to start, then after I had stopped for a bit would not start back up. I went through the fuel system and it is all good. I hooked up inline spark tester between the ignition coil and distributor and can't find any spark there. I tried disconnecting the tach, and no start still. I have read about trying to disconnect the shift interrupt switch but not sure how. I tried disconnecting the one wire it has to ground on the terminal block but it still did not start / still on spark. PO had replaced the distributor so it is new. Boat ran great first 5 times. Now nothing. Any ideas?
