cyclops222
- Mar 21, 2024
- 3,049
Blown head gasket can be to....water ...exhaust ....intake or a oil channell.
Oh no that is a bummer.Alright. Sorry it’s been a minute to retest. Bought a new compression tester and here are the results…
#1 - 150 psi
#2 - 90 psi
#3 - 145 psi
#4 - 150 psi
Did a wet test on #2 and minimal change. Slightly over 90.
Could it be the valves for #2?
If I had a blown head gasket I would have two adjacent low numbers correct?
If it was the piston rings then the wet test would have increased the numbers?
already established that the compression test wasn't ok...Often the flippers do rattle after an overheat. Do a quick compression test, if OK, then replace your flapper and be sure any bits and pieces are removed. Once your done, put boat in water and make adjustments to idle and idle speed, while in water and underway. My 3.0 idles nicely around 600/650 rpm
I would test it again after running italready established that the compression test wasn't ok...
If proper work was done, those flappers would have been replaced and the pieces removed!! Pull the head and get it reworked, valves ground, check all cylinders for scoring, reinstall with new head gasket and enjoy your boat. If you had done that to start....you would be cruising now, not still tinkering on your motor.The PO showed me receipts where he had head work done due to over heating my boat before I got it. I found flapper parts in the exhaust y pipe, and in the lower unit. Both flappers were toast.
