Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
This is a new engine 135HP, 4Cyl, with Carb.
Owners Manual says spark plug gap of .045 or .9mm. Problem is .9mm is the same as a .035 Gap so one is wrong.
The Repair Manuals I have read say .035. Which is it?
Thanks Don...the Merc Manual that came with the Motor has the noted discrepency that I mentioned. I will check the decal. I did e-mail Merc and they insist it is .045 but I don't think they thought about it before answering.
Hello,
Sorry to jump in the thread, but do you think its the same for the 3.0 LX ? I just happen to be doing a full tune up on a 97 3.0LX and I know the heads are different, so will that make a difference?
Ok -- I also have a '97 Glastron with the 3.0 -- BUT the engine number is "OK123456"; not an 'SN' number. Should I change the gap to 0.045"? The arrestor cap denotes gap as 0.035", but am wondering if I may perform better or pull more MPH/MPG with a change like this. Any recommendations on the BEST plug to use? Does it really matter? Have been using AC Delco in the past....
Thanks much!
You guys need to start new threads with your particular engines. The service bulletin doesn't work because it's a 2007 thread, and that ISP doesn't exist any more.
