MerCruiser 3.0 starter question
BillWilliams
I have a friend with a 2001 3.0 MerCruiser serial number M038073.
The starter solenoid clicks but the starter will not engage; however, if he directly jumps the starter wiring, the starter will engage and turn the engine over.
I assume this is probably an overall starter issue and replacing the starter will take care of it?
Thanks
dubs283
if the primary on the starter solenoid is having 12 volts applied and the starter turns then the starter and solenoid are fine. if bypassing the starter solenoid without testing it tells you the motor is good, but nothing about the solenoid
you can test the slave solenoid by checking for voltage at the starter solenoid primary with a voltmeter
see here:
