[FONT=Helvetica, Arial, Verdana, sans-serif]hello all,[/FONT]
[FONT=Helvetica, Arial, Verdana, sans-serif]Want to check in with the experts here and make sure I'm taking the right trail on this, already screwed up once.[/FONT]
[FONT=Helvetica, Arial, Verdana, sans-serif]June I bought a 2003 sea ray 175srx with a 3.0 mercruiser. First couple months seemed to run good, hard starting and rough idle so I ran some sea foam through it, seemed to help a bit, other thing that was very odd is I could get up to 5300 rpm with a 21' prob, mind you I'm at 5000ft, no way in the world it should of ever reached that high of rpm and I'd only do about 35mph, in any case I would just back it off to 4800. Talked to a couple of dealers, they just felt my rpm gauge was off but I always backed it off to be safe.[/FONT]
[FONT=Helvetica, Arial, Verdana, sans-serif]Come August I noticed oil leaking out once I removed the boats water drain plug. Took it out a couple more times after that and just topped off the oil, also had a few occasions where I would punch full throttle and it would run at 40% for a few minutes then all the sudden kick in full throttle, figured it was a carb adjust problem. Come October and I took a fishing trip up on high elevation lake (7000 ft) ran good all day, then on the way back I'm running full throttle (4800 rpm) and bam, horrible noise out of the engine. Engine would not restart, never saw the temp or oil gauge out of range, and when trying to restart it sounded like it struggled just to turn over.[/FONT]
[FONT=Helvetica, Arial, Verdana, sans-serif]Got her home, pulled plugs and did a compression check. Cylinder 1 no compression and spark plug destroyed, #2 no compression, 3 and 4 seem to be fine. So I have taken the route I have major damage and need a new engine (pissed)[/FONT]
[FONT=Helvetica, Arial, Verdana, sans-serif]Anyway I have gotten a few quotes from some local dealers, it has come down to 2. One of them says they can get me a mercury re manufactured 3.0 long block installed for about $3800 1 year warranty, he also keeps telling me he'll find something else that is wrong and price will most likely go up. Dealer 2 says he cant even get a reman mercury 3.0 from mercury (says they don't have any) but will install a brand new mercury 3.0 with 3 year warranty for $4400 and says that should cover it, he will also test my rpm gauge and adjust my carb for no additional cost, he is also given me a winter discount.[/FONT]
[FONT=Helvetica, Arial, Verdana, sans-serif]I have almost decided to go with the new motor with the longer warranty and dealer #2 I just have allot more trust in, I work with 2 people that have had major repairs done there and says they are great, also have been around for quite a while, respected marine shop in these parts. Dealer #1 with the reman I know nothing about.[/FONT]
[FONT=Helvetica, Arial, Verdana, sans-serif]Question I have is I'm I taking the right route, should I spend the extra $$ on a new motor and if not what other options are out there for re manufactured engines? I don't want to do the work, don't have the time plus I have medical problems that will make it tough on me. Any advice on this would be appreciated, I already bought a piece of junk and don't want to throw more $$ away, at this point just want a boat that works and is reliable. [/FONT]
[FONT=Helvetica, Arial, Verdana, sans-serif]Thanks in advance[/FONT]
