Mercruiser 350 MAG MPI
alldodge
I would start looking closer at the IAC and TPS.
Basically you gave the motor more air and it fired up
First post
only way we could get it to start was to use the throttle and crank it for a bit.
What where you doing during this time?
If you were moving throttle than back to idle, than crank, this would do nothing.
If you opened throttle slightly and it still did not start that is an issue
AusFox
When I was cranking and trying to use throttle it wouldn't start. Apparently before I got involved the only way they could get it to start after sitting hot was to work the throttle and it would start and rev up.
I agree by removing the Intake manifold sensor it sucked hard through that hole and fired straight away. I am also fitting a larger blower to the engine bay to help move air through.
alldodge
If throttle is moved move 3/4 to full throttle the ECM shuts off the injectors, so if it was flooding this should allow it to start if there is spark
Moving the throttle a bit to 1/4 throttle and it starts than this would lean toward the IAC and TPS.
I'm leaning toward the IAC without more analysis.
Remove the IAC and insure the tip of it and the bore it fits in is clean. With cable connected to the IAC turn the key ON (don't start) and watch the tip of the IAC. Does it move in/out?
Use a digital voltmeter and measure the TPS voltages to ground.
Gray = 5V
Black/Pink = Ground
Bark Blue/Orange = Reference
Key ON
Measure Gray for 5V to ensure it's exactly 5V
Measure Drk Blu/Org should read less than 1 volt. Keep measuring and move TPS from idle to WOT and see voltage increases smoothly close to 4.8V
Lpgc
Should be able to meaure voltages on the MAP sensor similarly to measuring voltages on the TPS as Alldodge described. Obviously there's a difference because the MAP sensor should output a voltage pointing to atmospheric pressure in the manifold when the engine isn't running, so you'd check MAP voltages with the engine running at various loads from idle to flat out.
Just some thoughts....
I don't know if these engines / ECUs switch from speed density (using the MAP sensor) to alphaN (using the TPS) if they detect a problem with the Map sensor as a type of limp home mode? If they do they probably won't start or run as well in alphaN mode as when using the map sensor.
During cranking the engine won't make much vacuum.. so during cranking the map sensor should give a signal pointing to close to atmospheric pressure whether the map sensor is installed in the manifold or not (if it's still wired up). The biggest difference removing the map sensor makes during cranking is the hole it leaves in the manifold allowing extra 'false air' to bypass the throttle so extra air gets in leaning the mixture. But then when it does start if the map is wired but not in the manifold it should give a signal pointing to the manifold being at atmospheric pressure when it's really under vacuum so should cause it to run rich... unless the ECU recognises that the signal is incorrect because the engine can't be at full manifold pressure with the throttle closed (which it reads from the TPS).
Was it definitely fuel and not water in cylinders when it locked up? If an engine gets water in cylinders it can soon damage rings and cause low compression.
AusFox
Hi Lpgc,
Thanks for the detail!!
When the engine locked up it was certainly fuel. When I take the MAP sensor out and the engine starts straight away I agree the reason it starts is because the extra air it's able to suck in through the hole.
I will look into the IAC operation and also the TPS and report back.
The frustrating part is the engine starts and runs better than ever when cold or if it has only been shut down for a couple of minutes, fuel economy is good for the size boat and we will travel 30 miles off shore without any type of engine trouble, we just know that after an hour or two fishing we have to pray we can get it started!!
Fun Times
Personally, with everything described of the engine defaults and things tried, I'd be concentrating on the MAP sensor from testing of all the circuits, the sensor itself and ultimately trying new MAP sensor that should be Merc part number 8M0087834 and ensuring the spark plugs are clean of fuel (running rich symptoms).
The MAP sensor is one of the heaviest working controls of the fuel calculations of this system to where if they go bad internally 'usually ends up as a running rich condition toppled with it's an intake air temperature reader too (< More fuel control)...
Also try physically touching the MAP sensor with a bit of say downwards effort to see if the symptoms change at all...I've had a few do that to me in the past.
Look down by your engine starter (starboard, rear side of the boat/engine) to see if there is a Mercruiser serail number tag mounted to the engine block.
Lpgc
Another thought - Did you change the engine oil after the stuck open injector problem? It will have caused fuel to wash into the engine oil. The engine will have some sort of a breather between crankcase and intake manifold. Fuel in oil is obviously bad for the engine, it thins the oil out, but it can also effect the air/fuel mixture when it evporates and enters the intake through the breather / PCV system. It effects the mixture a lot more when the engine is hot rather than cold because the fuel in oil evaporates more when it's hot.
Not sure about your engine dipstick setup, on my OMC Cobra Ford V8 setup the dipstick doesn't actually enter the sump, the dipstick tube runs under the sump and connects to what would be the sump drain plug hole in a car/truck engine. The oil in the tube finds the same level as oil in the sump but oil in the tube only ever mixes with oil in the sump when all the oil is drained (oil from tube flows into sump and/or gets sucked out of the tube if you empty oil via the tube) and when the empty sump is filled with fresh oil (new oil from sump flows into tube)... So on mine you can only tell the level of oil using the dipstick, you cannot tell the condition of oil because oil in the tube never mixes with oil in the sump, regardless of how old/dirty/contaminated oil in the sump gets the dipstick always comes out coated with fresh oil.
If you remove your oil filler cap and sniff the oil fill hole does it smell more fuelly than normal? Has oil level increased on the stick?
AusFox
Hi all,
I got down to the boat on the weekend! The oil has been changed and the TPS reads 0.63V in neutral and smoothly increase to 4.49V at WOT. I have ordered a replacement MAP sensor but that is yet to arrive, hoping that will be the final fix to this issue as the engine is performing above and beyond expectations with both power and economy!!
AusFox
UPDATE - Time to pull the heads off
Well it seems the more I find damaged or out of spec and rectify it leads us to another issue!!
After performing another leak down test the results are not great! The intake valves on the cylinders (1,2,3&4) are not seating well enough, I believe this is all as a result of the way the engine has run so poorly for a few years now. When testing comps and leak down its interesting how the cylinders further forward get worse, I am guessing this may be due to the angle the engine is at when under way.
Does anyone have the specs and information from the workshop manual for head removal/install?
AusFox
Ok, heads have all been reconditioned!! Compressions once engine is warm and with WOT are all between 170 & 180.
We got a quick water test in but conditions didn't allow us to spend too much time going over everything.
One thing I did notice was our top speed we have lost a couple knots. I need to get the boat out again in better conditions to confirm but we only pulled around 4400-4500RPM at WOT (38 Knots). My understanding is the 5.7 MAG MPI with Bravo 3 we should be looking to get around 4800-5000RPM. Can anyone confirm this?
If this is correct in your opinion what could be restricting us from getting the desired RPM and the owner believes prior to engine trouble, he was getting 43 knots.
It may be that in the better conditions we will get more RPM and higher top end speed, hull is not anti fouled and is clean, prop's are both clean and no damage.
Fun Times
Should it be still original, often if you look on the flame arrestor cover specification decal it will list what the RPM should be for the engine in question as some years varied for top RPM range on those engine models.
AusFox
Unfortunatly that sticker is not on this engine! Along with many other things!! haha
The engine is running great so far, I will get some fuel usage data soon and that will help tell us a little more.
In your opinion is revs are say 500RPM down, what could cause this?
alldodge
Your ECM post 4 shows the date of 2005
Being a 2005 your max WOT RPM is 4400-4800 per manual 31
AusFox
Testing in good conditions shows we are getting 4800 RPM. The owner said we are still about 2-3 knots (GPS tested) speed off what he has previously had however like I have explained to him top speed depends on swell, tides and wind also.
AusFox
Boat is running great!
I just now want to put a fuel flow meter in and check the fuel consumption. It currently has a flow meter that’s run through a Simrad GPS, this one is showing a very high fuel use when we are just motoring around looking for fish, so around 800-1000rpm. When sitting on 3000rpm (26 knots) the fuel rate is showing 1L per 1 mile
