Mercruiser 350 mag tow sport would not start today. Looking for anyones ideas as to why.
The motor is turning over by the starter motor but it does not fire. I tested it this morning and it fired a few times then went to take it out in the water and it stopped working. It was running 7 days ago when i took it out.
I checked the fuel line and it had fuel in it.
I poored some fuel down the manifold inlet directly into motor in case there was a lack of fuel. This did not work so I assume it is not lack of fuel.
I pulled out a lead from a spark plug and stuck a screw driver in it to check if it was getting spark and I could clearly see spark coming out of it. The spark plugs should be fine seeing it was running last week and they are not that old.
So I am out of ideas as to what is wrong. Anyone got any ideas ?
