I have a good friend and former co-worker with a 4.3 in his boat. he lost a plug and had both shutters drop in the y-pipe plugging up the exhaust. he couldnt get to WOT, and the dealer even gave him other props to try.
If you remove the outdrive, you can stick a water nozzle to the water inlet. A large diameter hose with a good pressure could allow higher rpms?
May have to take the drive off. It will be lodged down there.
I have a 2003 merc 4.3L and one of my exhaust shutters made it all the way into my outdrive. I found it when I split the drive to do the impeller. It was just the inner metal plate. All the rubber was gone. Mine was part # 807166A-1. Get one of the old ones out and measure it. There are a few different ones.
I guess that's my question. If I pull the drive off, will I be able to see the exhaust collector and see if the piece is there or will I have to remove other pieces as well?
I did manage to get the inspection camera from one side of the y to the other and did not see the piece. I know that it can't have disappeared though. Is it possible it's caught in the very bottom of the y where it goes into the outdrive/exhaust? I won't feel comfortable starting this thing up if don't know where that piece is is...
If it's in there then yes you will be able to see it, that is unless it was small enough to be spit out through the prop
Going from one side to the other and not seeing anything else you have a good chance the other piece is gone
One additional question because I have gotten conflicting advice - could this be my issue? In other words, could the exhaust clogged by the flapper cause my low WOT throttle issue? Some have said that it would only impact a few hundred RPM, not the couple of thousand RPM I am off right now.
How about the inline fuel filter at the carb inlet. You mentioned you replaced the fuel filter in the 1st post... which one.... the fuel water separator or the inlet filter at the carb?
